Christian
Inlägg: 86 Blev medlem: 3 november 2003, 22:54:49
Inlägg
av Christian » 23 januari 2010, 19:42:11
Har köpt en EM-411 gps-mottagare och kopplat in den på serieporten. Men jag får en massa konstiga tecken bara (se nedan). Jag har ställt in Hyperterminalen på 4800 bps. Måste man ändra nån annan inställning?
datablad till mottagaren:
https://www1.elfa.se/data1/wwwroot/webr ... 840002.pdf
&N2F6N2F6V22JVnb>6JrN:"..:F>>>NzN**2*F2>>NFN>:2>>F i9S&fffffsfffS&&
&f&Lff39s&&fffs2>NjN:N>.N2F6N::F>NJN.>FNJNN>>>>V&nJVnb>b2zNzN2N:&N>"N62N6>NNN
NNNNNN.F*N2F6N2F6V2>JVnb>6JrN:"..6>F>>>NzN**2*F2>>NFN>:2>>F2>NjN>F>N"*F*>N62
>::>NNV2.JV i9S&fff&fsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N::F>NJN.>
FNJNN>>>>V&.JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>6JrN:"..6:F>>>N
zN**2*F2>>NFN>:2>>F i9S&fffffsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N:
:F>NJN.>FNJNN>>>>V&"JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>b2&N2N:
N::N:2N"*N>".N6.N>"N.N:"6N2:N62N.:N>""N.>N>6N.>N6"NV"JVnb>b2&N2N6N::N>.N2"N66
6NN:>N26N6*NN:&N6>N>."N26N>N:"N:2N6.V">JVnb>b2&N2N2N::N>*N:.N2>>NN6>N:>N:6N6
N6N>N22NV.6JVnb>6JrN:".. i9S&fff&fsfffS&&&f&Lff39s&&fffs2:>NjN:N
>.N2F6N::F:NJN.>FNJNN>>>>V&"JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb
>6JrN:"..62F>>>NzN**2*F2>>NFN>:2>>F i9S&fffffsfffS&&&f&Lff39s&&fffs
2:>NjN:N>.N2F6N::F:NJN.>FNJNN>>>>V&>JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F
6V2>JVnb>6JrN:"..6.F>>>NzN**2*F2>>NFN>:2>>F i9S&fff&fsfffS&&&f&Lff3
9s&&fffs2:>NjN:N>.N2F6N::F6NJN.>FNJNN>>>>V&6JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F
*N2F6N2F6V2>JVnb>6JrN:"..6*F>>>NzN**2*F2>>NFN>:2>>F i9S&fffffsfffS&&
&f&Lff39s&&fffs2:>NjN:N>.N2F6N::F6NJN.>FNJNN>>>>V&:JVnb>b2zNzN2N:&N>"N62N6>NNN
NNNNNN.F*N2F6N2F6V2>JVnb>6JrN:"..6&F>>>NzN**2*F2>>NFN>:2>>F2:>NjN>F>N"F:*N62
>::>NNV2"JV i9S&fff&fsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N::F6NJN.>
FNJNN>>>>V&>JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>b2&N2N:N::N:2N"
*N>".N62N>"N.N:"6N2>N62N.:N>""N.>N>6N.>N6"NV"fJVnb>b2&N2N6N::N>.N2"N666NN:>N26
N6*NN:&N6>N>."N26N>N:"N:2N6.V">JVnb>b2&N2N2N::N>*N:.N2>>NN6>N:>N:6N6N6N>N
22NV.2JVnb>6JrN:".. i9S&ffffLsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N:
:F2NJN.>FNJNN>>>>V&jJVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>6JrN:".
.6F>>>NzN**2*F2>>NFN>:2>>F2:>NjN>F::N&6F*2N62>::>
/Christian
Nerre
Inlägg: 27354 Blev medlem: 19 maj 2008, 07:51:04
Inlägg
av Nerre » 23 januari 2010, 20:17:21
Vad har du som nivå-konvertering?
För om jag tolkar den där rätt så har den TTL-nivåer på porten (0 och 5 V), och din datorn har troligen RS-232-nivåer (3 - 12 V och -3 - -12 V).
Christian
Inlägg
av Christian » 23 januari 2010, 20:22:10
Det är en minilaptop och en usb-serieports konverterare, men kanske fortfarande är som du säger med olika nivåer?
Anders_Peter
Inlägg: 66 Blev medlem: 24 juli 2008, 00:40:30
Inlägg
av Anders_Peter » 23 januari 2010, 20:24:09
Precis som Nerre skriver så står det på sidan 3, 0-2.85volt TTL, sedan brukar man ställa in, baudrate, antal databitar, stopbitar, paritet, detta står om på sid 10.
/Anders
Christian
Inlägg
av Christian » 23 januari 2010, 22:03:31
Vilket är det lättaste sättet att konvertera från ttl - rs232? Max232?
Jag har även kopplat gps-modulen till en basic stamp, men den ska väl kunna läsa av ttl nivåerna direkt?
Anders_Peter
Inlägg
av Anders_Peter » 24 januari 2010, 01:08:04
MAX232 låter väl som ett vettigt förslag, har aldrig använt basic stamp men om den arbetar med 5v så borde det väl fungera.
Hillman
Inlägg: 64 Blev medlem: 25 januari 2006, 09:22:20
Inlägg
av Hillman » 24 januari 2010, 18:45:48
Jag har börjat använda dessa sladdar mer och mer, då slipper man hålla på med att koppla MAX232-kretsar hela tiden.
TTL-232R USB-TTL-kablage 3.3V I/O - Elfa-nr: 73-206-74
TTL-232R USB-TTL-kablage 5V I/O - Elfa-nr: 73-206-73
Icecap
Inlägg: 26726 Blev medlem: 10 januari 2005, 14:52:15
Inlägg
av Icecap » 24 januari 2010, 18:50:49
MAX3222
snigelen
Inlägg: 815 Blev medlem: 8 maj 2009, 11:02:14
Inlägg
av snigelen » 24 januari 2010, 22:55:50
Hillman skrev: Jag har börjat använda dessa sladdar mer och mer, då slipper man hålla på med att koppla MAX232-kretsar hela tiden.
Jo de är smidiga. Man får stabil spänningsmatning på köpet. Har man dessutom lagt in en bootloader innan så har man kommunikation, spänningsmatning och programmeringsinterface i en enhet, med fyra tåtar att koppla
sysop
Inlägg: 55 Blev medlem: 2 februari 2009, 16:14:05
Inlägg
av sysop » 24 januari 2010, 23:00:40
TTL -> CMOS är konstruktionsmässigt rätt. no doubt. Jag är dock inte säker på att detta är ditt problem.
Hur har du kopplat modulen?
Kollat på att ändra sirfbin -> NMEA?
