ks 0108 avr problem...
är total novis på att programmera c men ja har iaf skrivit ihop en kod (som inte funkar) för att testa min ks0108 display från fractronics... har kollat alla kopplingar och dom stämmer överens med koden... är de nån som är haj på detta så kanske den kanta sig en titt å se vad som är fel...
#include <avr/io.h>
#include <inttypes.h>
#include <avr/delay.h>
#define RS 0b01000000
#define RW 0b00100000
#define E 0b00010000
#define CS1 0b00001000
#define CS2 0b00000100
#define RST 0b00000010
int main()
DDRB = 0xff;
DDRC = 0xff;
//display on
PORTC = _BV(CS1);
PORTB = 0b00111111;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//set page address
PORTB = 0b10111010;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//set y address
PORTB = 0b01000110;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//start line
PORTB = 0b11000000;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//write data
PORTC = _BV(RS);
PORTB = 0b11111111;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
_delay_loop_1(30); //strobe data(javet inte fint men men....)
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTB = 0b00111111; //sätt displayen i läge on igen för att visa vad som finns i ramet....
#include <avr/io.h>
int main()
DDRB = 0xff;
DDRC = 0xff;
//display on
PORTC = _BV(CS1);
PORTB = 0b00111111;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//set page address
PORTB = 0b10111010;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//set y address
PORTB = 0b01000110;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//start line
PORTB = 0b11000000;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
//write data
PORTC = _BV(RS);
PORTB = 0b11111111;
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
PORTC = _BV(E);
_delay_loop_1(30);
PORTC = ~_BV(E);
_delay_loop_1(30);
- MicaelKarlsson
Du kan ju börja med delay på någon ms, sen när du får det att funka så kan du sänka den tlls det börjar flippa
Synd att jag inte har en likadan display i näven, är nämligen också mycket sugen på att försöka få igång en KS0108!
Jag hittade lite mumma här, mer specifikt är det nog den här appnoten som är av intresse.
Edit: Dumheter, E är 'la klocksignalen. På en HD44780 gäller att data till LCDn triggas på fallande flank, medans data från LCDn ges ut på stigande flank och försvinner på fallande, det kan vara så här med...
Kolla in databladet: http://www.fractronics.com/12864b_full.pdf
Står allt man vill veta och lite till. Har lite kod som jag kör på en mega32 och den där displayen om du vill ha?
kom fram till att den förra koden var skit.. har nu följt timing diagrammet i databladet och gissa vad?!! de funkar fortfarande inte...
#include <avr/io.h>
#define RS PC6
#define RW PC5
#define E PC4
#define CS1 PC3
#define CS2 PC2
#define RST PC1
int main()
DDRB = 0xff;
DDRC = 0xff;
//display on
PORTC |= _BV(E);
_delay_loop_2(210); //30ns
PORTC &= ~_BV(E);
_delay_loop_2(2400); //310ns
PORTC &= ~(_BV(RW) | _BV(RS) | _BV(CS1));
PORTC &= ~_BV(CS2);
_delay_loop_2(1200); //140ns
PORTC |= _BV(E);
_delay_loop_2(220); //30ns
PORTB = 0b00111111;
PORTC |= _BV(E);
_delay_loop_2(1600);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
_delay_loop_2(80); //10ns
PORTC &= ~(_BV(CS2) | _BV(RW) | _BV(RS) | _BV(CS1));
//set page address
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b10111010;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
//set y address
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b01000110;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
//start line
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b11000000;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
//write data
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b11111111;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000001;
#include <avr/io.h>
#define RS PC6
#define RW PC5
#define E PC4
#define CS1 PC3
#define CS2 PC2
#define RST PC1
int main()
DDRB = 0xff;
DDRC = 0xff;
//display on
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b00111111;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
//set page address
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b10111010;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
//set y address
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b01000110;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
//start line
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b11000000;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000000;
//write data
PORTC |= _BV(E);
PORTC &= ~_BV(E);
PORTC &= ~_BV(CS2);
PORTC |= _BV(E);
PORTB = 0b11111111;
PORTC |= _BV(E);
PORTC &= ~_BV(E);
_delay_loop_2(220);
PORTB = 0b00000001;
Det är mycket möjligt att man inte behöver någon delay. Kanske en enda nop om man nu vill vara på säkra sidan. Men varför bråkar du med delays när det inte fungerar som det ska överhuvudtaget? Ett för stort delay kan ju inte skada eftersom överföringen är synkron, så börja med några ms i delay överallt, sen när du fått igång displayen så kan du börja skärna ner på delayerna tills det inte går längre, om det nu är överföringshastighet du är ute efter.
Har du pinne 17 (Reset) inkopplad mellan displayen och avr'en?
Om ja: mät på den och kolla att den verkligen är satt hög (+5 volt). Är den 0'a så ligger diplayen i reset hela tiden och kommer inte att vilja fungera.
Om nej: Har du kopplat en sladd mellan pinne 17 på displyen och plus eller ligger den flytande? Dra upp den till plus isådanafall för säkerhets skull.
Förresten - vad händer när du kör programmet? Och vad förväntar du dig ska hända?
Fractronics datablad säger egentligen inget om huruvida RST är aktiv låg eller hög.
Men på
http://www.compsys1.com/workbench/On_to ... oller.html
och
http://www.skippari.net/lcd/ks0108.html
och Samsungs datablad för KS0108B http://www.perfectlcd.com/form/IC_spec/ ... ks0108.pdf
så är "Reset Active" låg, dvs den ska kopplas till plus vid normal drift.
Prova att lägg den på plus och se vad som händer.
Men på
och
