[3]
  • Test_mm.sldprt (SolidWorks part-file) [4]
  • Test_tum.sldprt SolidWorks part-file) [5]
STL
  • Test_mm.stl [6]
  • Test_tum.stl [7]
  • Test_mm.wings [8]
  • Test_tum.wings [9]
WRL
Test_mm.wrl [10]
Test_tum.wrl [11]
Skapa komponent i SolidWorks
Komponent ritad i SolidWorks
Redigering i Wings3D
Modellen färdigredigerad
Ändra renderingsalternativ
