STL
- Test_mm.stl [5]
- Test_tum.stl [6]
- Test_mm.wings [7]
- Test_tum.wings [8]
WRL
Test_mm.wrl [9]
Test_tum.wrl [10]
Skapa komponent i SolidWorks
Modellen färdigredigerad
Redigering i Wings3D
Ändra renderingsalternativ
