  • Test_mm.sldprt (SolidWorks part-file) [3]
  • Test_tum.sldprt SolidWorks part-file) [4]
STL
  • Test_mm.stl [5]
  • Test_tum.stl [6]
  • Test_mm.wings [7]
  • Test_tum.wings [8]
WRL
Test_mm.wrl [9]
Test_tum.wrl [10]
Skapa komponent i SolidWorks
Komponent ritad i SolidWorks
Modellen färdigredigerad
Redigering i Wings3D
Ändra renderingsalternativ
