Ytmonterade
Passiva
Dioder
"Fyrkantiga"
"Runda"
"SOT lookalike"
"Större kapslar"
Transistorer
SOT23 SOT143
Dual in-line
Quad in-line
QFP - Quad Flat Pack
QFN - Quad Flat pack No-leads
Grid arrays
BGA - Ball Grid Array
LGA - Land Grid Array
