Ytmonterade
Passiva
Dioder
SOD - Small Outlien Diode;
Transistorer
SOT23 SOT143
Dual in-line
Quad in-line
QFP - Quad Flat Pack
QFN - Quad Flat pack No-leads
Grid arrays
BGA - Ball Grid Array
LGA - Land Grid Array
