Ställer två frågor åt en god man i orgelbyggarbranschen:
I need a good transistor tester/characteristics meter. These appear to have fallen from fashion, since all we can find on the market are small test boxes of the 'go/no go' kind. We need a universal instrument that can measure the performance of different transistor types, with an accompanying transistor data manual, against which the health of ageing transistors can be compared. We especially need to measure Hfe of power transistors like the 2N3055, in order to produce matched pairs. Does anyone know where we could get hold of such an test instrument? We have a very good AVO valve characteristic meter, and it seems odd that we are unable to test transistors to the same degree of sophistication as our valves. Perhaps AVO made a transistor tester?
Top octave generator I.C.s Several attractive Hammond models from the 70's and early 80's have a top octave generator consisting of two separate I.C.s which are becoming hard to find. The Hammond part numbers are 075-047242 & 075-047243. Other commercial equivalent I.C.s have the following markings; S2555 & S2556, MC1183 & MC1184, MM5832N & MM5833N. Does anyone know where these can be obtained? Or has anyone designed a one-chip replacement board? [Note to technicians; these two I.C.s become noticeably warm under normal operating conditions, and their life-expectancy can be extended by fitting I.C. heat sinks]
Så, kan någon svara på frågorna tro?
Transistor-testare & div. ic-kretsar
- JimmyAndersson
Jag har letat men inte hittat några av kretsarna. Hammond brukar vara hjälpsamma, kanske du/frågeställaren kan hitta något hos dem?
Att mäta Hfe för att hitta matchande par borde man kunna göra genom att koppla upp transistorerna under så lika förhållanden som möjligt och helt enkelt mäta signalnivåer och frekvenser. Det finns säkert speciella mätinstrument för detta, men nog borde det fungera med ett tillräckligt bra oscilloskop eller liknande. Åtminstone för att hitta tillräckligt matchande transistorer så man inte kan höra någon skillnad.
