här kommer resultatet från uppladdningen av nedanstående programsnutt.
Tyvär är det en otrolig mängd text.
Något verkar dock vara fel.
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int sensorPin = A0; int sensorValue = 0; //initieringar och liknande här
void setup() {
Serial.begin(9600); // setup serial
void loop()
delay(1000);
Serial.print ("nasse");
lcd.print("kalle");
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bjorn\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\bjorn\AppData\Local\Temp\arduino_build_749570 -warnings=none -build-cache C:\Users\bjorn\AppData\Local\Temp\arduino_cache_443721 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\bjorn\Documents\Arduino\nissenasse\kalle\kalle.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bjorn\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\bjorn\AppData\Local\Temp\arduino_build_749570 -warnings=none -build-cache C:\Users\bjorn\AppData\Local\Temp\arduino_cache_443721 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\bjorn\Documents\Arduino\nissenasse\kalle\kalle.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\sketch\\kalle.ino.cpp" -o nul
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
-> candidates: [LiquidCrystal@1.0.7]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\sketch\\kalle.ino.cpp" -o nul
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src\LiquidCrystal.cpp
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\sketch\\kalle.ino.cpp" -o "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Kompilerar skiss...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\libraries\\LiquidCrystal\\src" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\sketch\\kalle.ino.cpp" -o "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\sketch\\kalle.ino.cpp.o"
Compiling libraries...
Compiling library "LiquidCrystal"
Using previously compiled file: C:\Users\bjorn\AppData\Local\Temp\arduino_build_749570\libraries\LiquidCrystal\LiquidCrystal.cpp.o
Compiling core...
Using precompiled core: C:\Users\bjorn\AppData\Local\Temp\arduino_cache_443721\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570/kalle.ino.elf" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\sketch\\kalle.ino.cpp.o" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570\\libraries\\LiquidCrystal\\LiquidCrystal.cpp.o" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570/..\\arduino_cache_443721\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570/kalle.ino.elf" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570/kalle.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570/kalle.ino.elf" "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570/kalle.ino.hex"
Using library LiquidCrystal at version 1.0.7 in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\bjorn\\AppData\\Local\\Temp\\arduino_build_749570/kalle.ino.elf"
Sketch uses 2732 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 232 bytes (11%) of dynamic memory, leaving 1816 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\bjorn\AppData\Local\Temp\arduino_build_749570/kalle.ino.hex:i
Problem uploading to board. See
https://support.arduino.cc/hc/en-us/sec ... 0003198300 for suggestions.
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean,
http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
processing.app.SerialException: Fel vid öppning av serieporten 'COM1'.
at processing.app.Serial.<init>(Serial.java:152)
at processing.app.Serial.<init>(Serial.java:82)
at processing.app.SerialMonitor$2.<init>(SerialMonitor.java:132)
at processing.app.SerialMonitor.open(SerialMonitor.java:132)
at processing.app.AbstractMonitor.resume(AbstractMonitor.java:132)
at processing.app.Editor.resumeOrCloseSerialMonitor(Editor.java:2126)
at processing.app.Editor.access$1300(Editor.java:116)
at processing.app.Editor$UploadHandler.run(Editor.java:2095)
at java.lang.Thread.run(Thread.java:748)
Caused by: jssc.SerialPortException: Port name - COM1; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.<init>(Serial.java:141)
... 8 more
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xac
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xac
avrdude done. Thank you.
