Sida 2 av 3
Re: Automatisk kabel-klipp/skalare
Postat: 2 april 2019, 07:04:01
av atulthakare.e
Anahka1975 skrev:...hela första inlägget...
Hi,
The circuit diagram JPG is not clear. Can you please upload clear one.please provide component list of project.
Postat: 2 april 2019, 07:31:55
av Anahka1975
Hi Atulthakare,
What is not clear in the schematics, did you click on it to get large version?
The component list is not that advanced, just an Arduino Nano, a DC/DC converter 5V output, a stepper motor driver, 2 servos, a 4x20 Display and a 10K potentiometer.
There is also a 0 Ohm resistor for the backlite to the display. Change to what value is suited to your display.
You could build this easy on a vero-board or just wire the modules together.
Good Luck on your build.
And if you like my entry in the contest please vote for it in this link
https://elektronikforumet.com/forum/vie ... 28&t=94522
Postat: 2 april 2019, 16:36:26
av rvl
atulthakare.e skrev:Hi,
Klickade du på bilden och sen på bilden som då öppnades?
Postat: 2 april 2019, 17:17:23
av atulthakare.e
rvl skrev:atulthakare.e skrev:Hi,
Hey the diagram is clear but it's not complete snap. Please post full circuit diagram with clear jpg
Postat: 2 april 2019, 17:51:09
av MadModder
Click/tap on the original schematic in the first post. Now the full schematic is there, big and clear, and you can zoom in on it if you're on a mobile device. Works in Chrome, Firefox, and Safari.
Maybe try something else than tapatalk.
Postat: 2 april 2019, 18:11:58
av atulthakare.e
MadModder skrev:Click/tap on the original schematic in the first post. Now the full schematic is there, big and clear, and you can zoom in on it if you're on a mobile device. Works in Chrome, Firefox, and Safari.
Thanks for support. it's worked.
Postat: 3 april 2019, 16:43:03
av atulthakare.e
Do you have it's pcb Gerber file or snap
Postat: 3 april 2019, 18:12:40
av Anahka1975
No pcb files unfortionatlly.
Postat: 6 april 2019, 10:46:08
av atulthakare.e
Hi,
What's the guage of your wire which you are cutting and stripping on that machine?and also one thing the pdf and cdr files are not opening.
Postat: 6 april 2019, 11:14:20
av MadModder
The files are downloaded when you cklick on them. You have to open them manually. The files are working very well. PDF tested with Adobe reader and Foxit Reader.
Postat: 6 april 2019, 11:18:17
av atulthakare.e
What's the guage of your wire that your stripping
Postat: 6 april 2019, 11:27:40
av MadModder
I don't know. It's not my project.
And please stop quoting the post directly above your post.
Postat: 6 april 2019, 11:33:16
av atulthakare.e
atulthakare.e skrev:MadModder skrev:The files are downloaded when you cklick on them. You have to open them manually. The files are working very well. PDF tested with Adobe reader and Foxit Reader.
Okay..Not gonna disturb you again
GOOD BYE
Postat: 6 april 2019, 11:37:51
av MadModder
lol... You know, you can post an answer in Tapatalk without tapping the quote button.
Postat: 6 april 2019, 12:15:58
av atulthakare.e
Okay
