Hur svårt kan PWM vara?
Postat: 1 november 2019, 14:30:05
Försöker få igång nåt så enkelt som PWM på STM32l431 men den bara vägrar. PA8 blir hög istället för att bli en PWM på 4 kHz. Har säkert missat nåt enkelt....vad kan det vara?
HW_TIM_PWM_Set(4000, 70);
HW_TIM_PWM_Enable();
HW_TIM_Delay(1000);
HW_TIM_PWM_Disable();
void HW_TIM_PWM_Set(uint16_t freq, uint16_t duty)
uint32_t period;
period = 140 -(freq /100);
period = period *20; // Lite osäker...
uint16_t PULSE_VALUE = (period * duty)/100;
uint16_t PrescalerValue = 0;
/* Compute the prescaler value */
PrescalerValue = (uint16_t) ((SystemCoreClock /2) / 4000000) - 1; // 4 MHz PWM
printf("PWM: period %d prescaler %d puls %d \n\r", (int)period, PrescalerValue, PULSE_VALUE);
PWMTimHandle.Instance = TIM1;
PWMTimHandle.Init.Prescaler = PrescalerValue;
PWMTimHandle.Init.Period = period;
PWMTimHandle.Init.ClockDivision = 0;
PWMTimHandle.Init.CounterMode = TIM_COUNTERMODE_UP;
PWMTimHandle.Init.RepetitionCounter = 0;
if (HAL_TIM_PWM_Init(&PWMTimHandle) != HAL_OK)
printf("Error TIM!\r\n");
return;
sConfig.OCMode = TIM_OCMODE_PWM1;
sConfig.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfig.OCFastMode = TIM_OCFAST_DISABLE;
sConfig.OCNPolarity = TIM_OCNPOLARITY_HIGH;
sConfig.OCNIdleState = TIM_OCNIDLESTATE_RESET;
sConfig.OCIdleState = TIM_OCIDLESTATE_RESET;
sConfig.Pulse = PULSE_VALUE;
if (HAL_TIM_PWM_ConfigChannel(&PWMTimHandle, &sConfig, TIM_CHANNEL_1) != HAL_OK)
printf("Error PWM!\r\n");
void HW_TIM_PWM_Enable()
GPIO_InitTypeDef GPIO_InitStruct;
__HAL_RCC_GPIOA_CLK_ENABLE();
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_MEDIUM;
GPIO_InitStruct.Alternate = GPIO_AF1_TIM1;
GPIO_InitStruct.Pin = GPIO_PIN_8;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
if (HAL_TIM_PWM_Start(&PWMTimHandle, TIM_CHANNEL_1) != HAL_OK)
printf("PWM start error\r\n");
void HW_TIM_PWM_Disable()
HAL_TIM_PWM_Stop(&PWMTimHandle, TIM_CHANNEL_1);
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_8, GPIO_PIN_RESET);
