Nej det är samma som jag, däremot ska inte rst vara low konstant utan bara under initieringen... kollar på Adafruits egen kod och ska försöka lägga till den i BPHermansson's men är bara copy/paste programmerare så får se hur det går!
Tänker dels på rst men framförallt kanske deras hint om HCW modulen:
Citera:
// If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
// ishighpowermodule flag set like this:
rf69.setTxPower(20, true); // range from 14-20 for power, 2nd arg must be true for 69HCW
Nedan är från deras instruktioner:
if defined (__AVR_ATmega328P__) // UNO or Feather 328P w/wing
define RFM69_INT 3 //
define RFM69_CS 4 //
define RFM69_RST 2 // "A"
define LED 13
endif
We begin by setting up the serial console and hard-resetting the RFM69
void setup()
Serial.begin(115200);
//while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
pinMode(LED, OUTPUT);
pinMode(RFM69_RST, OUTPUT);
digitalWrite(RFM69_RST, LOW);
Serial.println("Feather RFM69 RX Test!");
Serial.println();
// manual reset
digitalWrite(RFM69_RST, HIGH);
delay(10);
delay(10);
Initializing RadioOnce initialized, you can set up the frequency, transmission power, radio type and encryption key.
For the frequency, we set it already at the top of the sketch
For transmission power you can select from 14 to 20 dBi. Lower numbers use less power, but have less range. The
second argument to the function is whether it is an HCW type radio, with extra amplifier. This should always be set to
true!
if (!rf69.init()) {
Serial.println("RFM69 radio init failed");
while (1);
Serial.println("RFM69 radio init OK!");
// Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
// No encryption
if (!rf69.setFrequency(RF69_FREQ)) {
Serial.println("setFrequency failed");
// The encryption key has to be the same as the one in the server
uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
rf69.setEncryptionKey(key);
