FlatCAM; en massa småfiler ...[LÖST]
Postat: 29 september 2018, 17:21:16
Jag undrar om någon vet hur man gör för att få alla enskilda sträckor att bli till en CNC-fil?
Svenskt forum för elektroniksnack.
https://elektronikforumet.com/forum/
I have multiple Geometry Objects but want a single G-Code file.
01/03/2015
As of version 8 you can cambine/merge Geometry objects. Simply select the objects that you want to caombine from the project list and click on Edit → Join Geometry.
Now you can create a single CNC Job from the resulting Geometry object.
