3D-Print Ramps med tillbehör.
Har provat 2 olika stegmotordrivare till denna.
A4988 som verkar ha varit standard och en förbättrad variant:
DRV8825 som jag kan rekommendera som uppgradering. Mer ström & fullsteg- 32ustp
Nackdelar: Dokumentationen är lite förvirrande och strömjusteringspot.en är bakvänd
Enkel strömjustering: Mät Ojumprad= fullsteg,stillastående V från pot. mitt till GND. Strömmen = 2xV i A .
Vet inte om detta gäller från alla tillverkare. Mina från GE-tech.
Pris ca 38:- Edit Pris 2016 nu ca 15Kr
Description
The DRV8825 stepper motor driver carrier is a breakout board for TI’s DRV8825 microstepping bipolar stepper motor driver. The module has a pinout and interface that are nearly identical to those of our A4988 stepper motor driver carriers, so it can be used as a higher-performance drop-in replacement for those boards in many applications.
The DRV8825 features adjustable current limiting, overcurrent and overtemperature protection, and six microstep resolutions (down to 1/32-step). It operates from 8.2 – 45 V and can deliver up to approximately 1.5 A per phase without a heat sink or forced air flow (rated for up to 2.2 A per coil with sufficient additional cooling).
Features:
1. Simple step and direction control interface
2. Six different step resolutions: full-step, half-step, 1/4-step, 1/8-step, 1/16-step, and 1/32-step
3. Can interface directly with 3.3 V and 5 V systems
4. Over-temperature thermal shutdown, over-current shutdown, and under-voltage lockout
5. Short-to-ground and shorted-load protection
6. 4-layer, 2 oz copper PCB for improved heat dissipation
7. Exposed solderable ground pad below the driver IC on the bottom of the PCB
8. Module size, pinout, and interface match those of our A4988 stepper motor driver carriers in most respects (see the bottom of this page for more information)
9. Adjustable current control lets you set the maximum current output with a potentiometer, which lets you use voltages above your stepper motor’s rated voltage to achieve higher step rates
10. Intelligent chopping control that automatically selects the correct current decay mode (fast decay or slow decay)
11. 45 V maximum supply voltage
12. Built-in regulator (no external logic voltage supply needed) Jo +5V för sleep PU
Edit OBS pluggas in med trimpotten vänd åt andra hållet jämfört med A4948!
Description
Features:
Re: 3D-Print Ramps med tillbehör.
Arduino Mega'n tuggar 1/16 som mest skall du köra med 32 får du kliva upp till en Arduino Due
Men det måste väl bero på en del olika faktorer: T.ex printspeed mfl. beräkningstunga ops.
Hur märker man om taket är nått?
På snabbförflyttning märker jag bara vibrations minskning. Har inte fått till printning ännu.
När jag slog i taket blev mina prints bara långsamma, även om jag ökade hastigheten betydligt så var det segt.
Arduino Due / Ramps-FD Finns det LCD/ Controlpanel som passar ihop med dessa på3.3V?
Har kört med dessa i 1/32 ustep i mer än 1.5 år nu och inte märkt att det skulle vara några problem ihop med Ramps.diesel skrev:Arduino Mega'n tuggar 1/16 som mest skall du köra med 32 får du kliva upp till en Arduino Due
Det är nog först om man har en riktigt snabb skrivare som det kan bli en begränsning.
Edit: Eller speciellt för en delta som kräver fler beräkningar.
- ghost_rider
